Activity Forums Adobe Premiere Pro JKL doesnt work backwards in source monitor
  • JKL doesnt work backwards in source monitor
    Posted by Gints Apsīts on August 11, 2005 at 6:19 am
    im using premiere pro 7 & 1.5, JKL doesnt work backwards play (“J”) in source monitor. is that normal in premiere?
    Craig Howard replied 21 years ago 4 Members · 9 Replies
  • 9 Replies
  • David J
    August 11, 2005 at 12:16 pm
    Works for me OK.
  • Craig Howard
    August 11, 2005 at 11:34 pm
    In my system “JKL” are shuttle controls for the Timeline Window only and they have no effect in the Source Window.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • David J
    August 12, 2005 at 7:28 am
    That’s two of you with the problem then. As I said, JKL works in both source and program windows on my system.
  • Mike Velte
    August 12, 2005 at 12:09 pm
    J does not work in source window for non-DV video.
  • Craig Howard
    August 12, 2005 at 8:37 pm
    Possibly a Matrox “thing” ?
  • Craig Howard
    August 12, 2005 at 8:50 pm
    I am not at my NLE to retry this, but I had a thought and question for David…. how does your Program or Source Window know which Monitor to control with “JKL” ???
    If I use it from the Timeline it controls (displays in)the Program Monitor(s) and I do this all the time but how does one focus the “JKL” control to the Source Monitor? I use the arrow keys to achieve that so its no big deal. ( I am just curious)
    Craig
    Auckland
    New Zealand
  • David J
    August 12, 2005 at 9:12 pm
    Click in the source monitor to make it active, then JKL applies there.
    I guess you can also tab between windows and watch the blue topbar if the mouse is infra dig.
  • Craig Howard
    August 13, 2005 at 5:48 am
    It must be a Matrox issue then because I am unable to select (focus) those monitors in that manner- although I can use all the controls under each of those. ( except Title Safe & the Zoom)
  • Craig Howard
    August 14, 2005 at 11:24 pm
    Correction to my previous posts.
    I am able to “JKL” in both these Windows and I can shift focus from Source to Program Monitors.
    Craig
    Auckland
    New Zealand
