Jittrey Footage From FCP to a DVD
YES – I’ve searched far and wide through these forums, but none of the threads seem to answer my question.
My timeline is HD…
1920×1080
square pixels
Field Dominance – Upper
Compressor: DVCPRO HD 1080i60The timeline contains all sorts of source footage, which I’m sure is the culprit. It contains 1080iHDV, anamorphic 16×9 DV NTSC and regular 3:2 DV NTSC footage.
Usually, I will just play with the shift fields filter and hope that’s what will fix it. It looks like the only footage I’m still having trouble with is the SD footage, but only if I applied speed changes to it. For example, if I slow a clip down, speed it up, use a variable speed, etc – it looks perfect playing from my timeline, but jittery once on the DVD.
After I export to QuickTime, I compress to MPEG-2, with a 16×9 aspect ratio. I then go into DVDSP and burn that m2v file. Then Bam! Jitters on those shots…
Any thoughts??
