Activity Forums Adobe After Effects Jittery stills on pan
  • Jittery stills on pan
    Posted by Romchi on August 18, 2005 at 6:31 pm
    Hi there,
    I am Pannig a long strip composition on to a 720X480 DV Comp. The pre comp was a huge comp I set up all my “elements” to make a photomontage.
    I outputed the huge comp and embedded in to the new out put comp (720X480) and 29.97 frame rate. However my pan looks jittery, as if frame are lacking to fill the motion. I have tested Motion blur. it didn’t change the end result.
    should I create the photomontage comp on a higher frame rate like 60 frames per sec . and then embed it on to the 29.97 comp.
    Or is this a interlace problem?
    Rom
    Romchi replied 20 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
