Activity Forums Apple Final Cut Pro Legacy Jittery footage
  • Jittery footage
    Posted by Steven Berry on December 8, 2009 at 1:49 pm
    Hey everyone, just had a question about some jittery footage in Final Cut Pro.
    The footage looks fine in the source window and everywhere else, but when I add it to the timeline it seems to have a “strobe” effect applied.
    I’ve tried exporting the footage and some clips still have the jitters.
    Any suggestions?
    Raymond Tuquero replied 16 years, 9 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    December 8, 2009 at 2:24 pm
    What are your sequence settings, and what are the properties of the clips you’re putting in that sequence? Sounds like you have a field order problem.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Steven Berry
    December 8, 2009 at 2:49 pm
    It’s only on selected clips, checking settings now.
    Is there anything that would cause some clips to strobe and others not to?
  • Raymond Tuquero
    December 8, 2009 at 5:01 pm
    Lighting could strobe footage, indoor fluorescent lighting for instance can flicker footage, Slow Shutter Speed … and like Jerry stated the fields can contribute to that as well.
    If your settings are all correct and the Field Dominance matches your sequence settings … I would look into FurnaceCore’s Plug-In: DeFlicker Filter. For me it worked great.
    Our issue was we shot a project in Australia and the lighting there runs differently than here. So when we came back to the States our editing bay saw the Fluorescent Flicker … FurnaceCore’s flicker filter was the best and easiest way to fix that.
    Nothing else worked in the default effects of FCP or AE CS3.
    -Raymond Tuquero-
    Houston Based Freelancer
    http://www.rtuqvidere.com
  • Steven Berry
    December 8, 2009 at 5:33 pm
    It’s more of strobe or motion effect than a flicker. Looking for a solution within the settings, or atleast without adding any more plugins
  • Raymond Tuquero
    December 9, 2009 at 3:18 pm
    Have you tried the Flicker Filter in FCP??? and maybe even the Shift Fields effect?? Or a combination of the 2??
    -Raymond Tuquero-
