Activity Forums Apple Final Cut Pro Legacy Jittery Dissolves in 24p
  • Jittery Dissolves in 24p
    Posted by Raafi Rivero on September 8, 2005 at 4:56 pm
    I’ve been editing on a 24p sequence with footage shot on the SDX900 (DV50 codec). For some reason, the dissolves all seem to become jittery after awhile. Generally, they’re smooth when I first cut them into a sequence, but after working on other sequences, or whatever, they usually tend to skip somehwat. One workaround I’ve found is to disable, then enable all of the offending clips. It works for the immediate minutes after I’ve tried it, but generally the jitters come back.
    I’m wondering if this is a drive issue — using firewire LaCie’s — as in maybe the drive/system is having problems pulling the footage fast enough from the drives and threading it together properly. I also have my sequences set to unlimited RT.
    Or is this an issue inherent to 24p?
    I’ve also tried exporting the sequences, and they still appear to have jumpy dissolves. Any ideas?
    thanks.
  • Bouncing Account needs new email address
    September 8, 2005 at 7:03 pm
    [Raafi Rivero] “I’m wondering if this is a drive issue — using firewire LaCie’s — as in maybe the drive/system is having problems pulling the footage fast enough from the drives and threading it together properly. I also have my sequences set to unlimited RT.”
    Sounds about right to me, RR.
    Firewire drives are not officially “recognized” by Apple for video editing, even in DV25.
    You should be using an internal HD or even a RAID for DV50.
    DV50 puts much MORE demands on the drives and FW bus.
    Have you RENDERED all of your effects?
    Dissolves are certainly effects and all effects SHOULD BE RENDERED for them to play smoothly.
