Activity Forums Adobe After Effects Jitter on certain layers
  • Jitter on certain layers
    Posted by Nick Vaka on March 14, 2019 at 3:12 pm
    Hello Creative COW,
    It has been a LONG time since I’ve posted but I’m frankly out of ideas and I’ve had great luck seeking advice here in the past.
    In sum, I have a team working on a big project that has numerous timeline animations like the one I’m asking about here, and they all have certain graphics that are jittering slightly as they slide across the screen. Here is an example an example.
    The graphics jittering in this shot are the fridge, the soup, and the black borders of the frozen food isle at the end. I’ve been working on the fridge layer. First, some project details.
    Framerate: 29.97
    3D layers with 3D Camera parented to null object sliding across the comp. Ease in/out applied to the 2-keyframe camera animation
    Basic 3D renderer
    No lights
    Tint applied to the layer
    Rendering as ProRes422 HQ
    The fridge layer is a PSD with no vector smart objects. The flicker happens if I solo the layer too
    Fridge is precomposed on the timeline
    Here’s the short list of what I’ve tried to so far. Everything has resulted in the same flicker, so I think it is the file.
    • Directional blur (horizontal and then vertical)
    • Fast blur (.7)
    • Unnested the layers and adding them directly to the timeline
    • Posterized the edges (Photoshop)
    • Changed the color profile
    • Removed all effects
    • Copied the layer and camera to a new composition
    • Made every comp a uniform frame rate using RD_Compsetter
    • Changed the framerate to 30 FPS
    • Made the fridge 2D and moved it across the screen in a new composition
    • Changed the fridge layers position on the Z Axis
    • Ensured PAR was consistent
    • Rendered as drop frame & non drop frame
    • Rendered as a PNG sequence and re-output to ensure it wasn’t the render itself
    • Made all layers in fridge 3D (the base was 2D before)
    • Ensured nothing sits on the same position on the Z axis
    The file flickers on the other guy’s machine too, but he isn’t noticing it. The client is.
    Any and all help is greatly appreciated. Client has been pretty patient, but the time we’ve spent troubleshooting this has got to be wearing on them
    Nick Vaka
    Motion Graphics & Animation
    https://www.nickvaka.com
    Scott Thomas replied 7 years, 5 months ago 7 Members · 20 Replies
  • 20 Replies
  • Steve Bentley
    March 14, 2019 at 4:41 pm
    Does it have to be 3D? Everything I see there could just be done with fake parallax shift in 2D.
    I thought it might be something with the prores but your timer slider on the bottom is really clean.
    I didn’t see AE’s built in motion blur in the list. Is that turned on for that layer? and in the render settings?
    The fridge is a different quality than the other graphics, almost as if its been blown up in a sub comp. Is the move happening in a sub comp or are there two cameras (one in the outer an one in the inner) competing?
  • Nick Vaka
    March 14, 2019 at 5:24 pm
    Thanks for the reply here.
    The comp doesn’t need to be in 2D, but putting the fridge in a 2D comp as a 2D layer by itself isn’t fixing the issue.
    Built in motion blur was on and I turned it off. Either way garnered the same result. Render settings was “On for checked layers”
    Per my post, the fridge was in a nested comp, and I took its layers and put them directly into the main comp.
    The fridge is actually much larger than the frame. It has been scaled down to 52%, but it does this nonsense at 100% scale too. There is only one camera in the entire scene.
    Nick Vaka
  • Nick Vaka
    March 14, 2019 at 5:50 pm
    *The comp doesn’t need to be in 3D (sorry)
    Nick Vaka
  • Steve Bentley
    March 14, 2019 at 5:54 pm
    If you just take the fridge element in a new project and just run it across the screen on a light background, do you get the same thing?
    You could also try reducing the black levels for this element, it might be the rolloff on the antialiasing is having to do too much in a short span: going from super black to white.
  • Nick Vaka
    March 14, 2019 at 6:47 pm
    I had the same problem before when I ran it over alpha. I just tried it over a teal background and the levels adjusted per your note. It’s still having the same issues. Very strange.
    https://youtu.be/DIvYeONGQbs
    Nick Vaka
  • Steve Bentley
    March 14, 2019 at 6:49 pm
    If it does end up to be an alpha issue, you could try changing the alpha to premult or straight.
  • Nick Vaka
    March 14, 2019 at 7:10 pm
    Just changed it from straight to premult and got the same result. Very frustrating.
    Nick Vaka
  • Cassius Marques
    March 14, 2019 at 7:47 pm
    There is nothing wrong with that project. You’re just being too attentive to details there.
    That judder is being caused by the combination of the layer’s velocity and your FPS amount. To reduce you could try to change the speed, even increasing the movement may easy it a bit.
    But that is extremely normal, I’m betting your client won’t even notice it after all the post is added to that comp. Once you color correct, add a bit of noise, and maybe some texture/color bleeds to the whole shot (anything that reduces the overall contrast) it won’t even be perceivable to our trained eyes.
    My advice, after having strained ages with rolling credits, is to just go with it. Its fine as it is.
    Cassius Marques
    http://www.zapfilmes.com
  • Nick Vaka
    March 14, 2019 at 8:51 pm
    That is personally where I’m at, but the client mentioned it and it’s a really particular client. Additional texture might be the ticket. I’ll fiddle around with it a bit more before throwing in the towel.
    Much obliged.
    Nick Vaka
  • Kalleheikki Kannisto
    March 15, 2019 at 5:00 pm
    The default setting of 180 degrees motion blur is a compromise between smoothness and sharpness. If you make it 360 degrees you will get maximum smoothness, but the images will look somewhat “smeared”. If you need to prioritize smoothness over sharpness, you can try that (if you haven’t).
    Senior Graphic Designer
