Activity Forums Maxon Cinema 4D Jiggling Text
  • Jiggling Text
    Posted by Simon Roughan on June 5, 2012 at 9:26 am
    HI
    I have a logo thats 7 extrude nurbs grouped in a null. I want it to slide in and the stop with a bouncy, jiggly motion. I cant work out how to get my logo into a simple editable object so i can apply the jiggle deformer. Im sure im missing something simple.
    Thanks in advance.
    Simon
    A picture is only as good as the glass it comes through. And the person using the camera has something to do with it too.
    Ben Peterson replied 11 years, 1 month ago 4 Members · 3 Replies
  • Emmet Reddy
    June 5, 2012 at 2:04 pm
    You could make all your extrude nurbs editable then select all your editable polygons and connect together so you only have one polygon and work with?
  • Adam Trachtenberg
    June 5, 2012 at 7:37 pm
    You can group the extrude objects and the jiggle deformer under a connect object. Rough example: 4244_jigglemultipleobjects.c4d.zip
  • Ben Peterson
    August 10, 2015 at 12:16 am
    I have some objects inside a null set up to morph between poses with pose morph. I want to use the jiggle effect to give it a some spring. I tried as Adam says but doesn’t work for what Im doing. The first thing I notice is that one of my objects stops morphing and the rest deform horribly. How would i do this?
