Jerky playback on Cinema HD monitor only
Hi: We are running FCP 5.1.4 on a G5. We have been cutting at 23.98 (footage that was captured at 29.97 and reverse telecined) and outputting through a Kona card to an ntsc monitor and/or dvd recorder.
I have been on the project for 2 months with no problems. Suddenly this week, my playback on the computer monitors only seems jerky. My output through the Kona card to the recorder and monitor is fine. I have double-checked my fcp settings, nothing seems to have changed. (playback output is through AJA Kona 525i29.97 8 bit (720×486), mirrored on desktop.
I talked to Kona support, because the playback on the ntsc monitor is fine, they think it is a problem with the software or my graphics card. Also, in the last few days (I can’t say for sure if it was the same day the jerky playback started)., after I boot up, the folders and icons which usually appear on the right monitor are partly appearing on the right monitor – kind of ghosting. As soon as I click anywhere on the desktop, it reverts to it’s correct position.
Could a setting on my graphics card have changed? Could it be going south? Any other ideas?
Lara Johnston
