Activity Forums Adobe After Effects Japanese Rising Sun
  • Kevin Camp
    September 30, 2010 at 7:47 pm
    todd has an easy method for creating radial rays that may work for you…
    https://blogs.adobe.com/toddkopriva/2009/05/radial-rays-project-parameteri.html
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    September 30, 2010 at 8:10 pm
    actually and even easier way may be to just make a circular shape layer using the ellipse shape tool.
    twirl down the shape properties, then stroke properties and set the stroke color to red, enable the dash settings (hit the + by the dash settings) and increase the stroke size a lot.
    from there you can probably just tweak those settings to create the sun.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Art Meier
    October 1, 2010 at 12:28 am
    This is exactly what I was looking for. Thank you very much.
  • Todd Kopriva
    October 1, 2010 at 7:04 am
    Kevin pointed to the first post that I made on this topic, but I also have a second that gives a somewhat better approach (similar to what Kevin gave in his second post):
    https://blogs.adobe.com/toddkopriva/2009/07/radial-rays-take-2.html
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
