Activity › Forums › Adobe After Effects › Jagged Text
  • Jagged Text
    Posted by Tvnewzcam on April 19, 2007 at 1:15 am
    I’ve tried everything to get rid of the jagged edge on some text in AE
    I created the original text in AE.
    I then recreated the text in illustrator and imported using every file format.
    I tried it photoshop as a PNG file
    Nothing has worked, any ideas?
    Michael Duff replied 19 years, 5 months ago 2 Members · 1 Reply
  • Michael Duff
    April 19, 2007 at 2:30 am
    you should read the post about three down from this one…. I’m sure it will answer your question.
    in addition…. if you are importing from Illustrator make sure you save as .ai or .eps – then when they are in the timeline select the continuously rasterise button (look in the help to find it)
    any bitmap file (png, bmp, jpg, psd etc etc etc) will get jaggies as soon as you scale above 100%
