Activity › Forums › Adobe Premiere Pro › Jagged edges in premiere pro cs4
Posted by Mitch Hardison on April 17, 2010 at 6:58 pmAll the videos I render out in Premiere Pro CS4 have jagged edges around everything in the video. I am rendering .mov’s at 100% quality but it looks pixelated and jagged. What can I do to get a sharp picture like I do when I render out of after effects?
Mitch Hardison replied 16 years, 5 months ago 5 Members · 16 Replies -
Vince Becquiot
April 18, 2010 at 6:51 pmThere could a few reasons. First, make sure that the Quicktime preferences are set to play at high quality. Also render in square pixels and make sure the PAR is interpreted correctly if you are bringing clips from After Effects.
A bit more info would certainly help. File origination, timeline format, output/render format/codec used, bit rate, resolution, effects applied.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Mitch Hardison
April 19, 2010 at 12:15 amThanks, I will try to render in square pixels and see if that helps first. If not I will give you the other info.
Mitch Hardison
April 19, 2010 at 12:40 amI tried square pixels but it did not help plus I had black bars at the top and bottom of the video. Here are all the settings I was using.
Quick Time
NTSC DV Widescreen
720×480, 29.97, Progressive, Quality 100
DV/DVCPRO – NTSC
Render at Maximum Depth is checked
Codec Settings: 24 bit
Optimize Stills is checkedI do not know about file organization or timeline format. I applied no effects I just sometimes add the audio in premiere instead of AE because I find it easier to edit that way
Jeff Brown
April 19, 2010 at 1:39 pmAh, my bet is on the QTime “quality” bug: DV is not set to play at best quality by default in QT Player.
Open your rendered .mov in QT Player,
Go to Show Movie Properties->
select the Video Track ->
select Visual Settings tab.Look at the lower right. Check the “High Quality” box.
Then ‘save’ to preserve the setting.It’s been stupid like this for about 10 years…
-jeff
Mitch Hardison
April 19, 2010 at 2:31 pmThe only setting like the one you are talking about I could find was under Preferences. I went there and checked use high-quality video settings when available. It still played the same way. All the videos that i render straight out of AE look great in quick time though. I don’t think it is the player because it also looks the same in vlc. It is something with premiere I just can’t figure out what. I thought I had done everything to render the file out at the highest quality possible but it does not look very good. Thanks anyway Jeff
Vince Becquiot
April 19, 2010 at 5:08 pmHi Mitch,
Sounds to me like the real issue is that you are exporting to DV, which will wreck havoc on graphics.
I would try Quicktime H.264 instead (start at 3 Mb/s).
Again, make sure you choose a square pixels resolution, in your case 864×480 (1.0)
Vince Becquiot
Kaptis Studios
Mitch Hardison
April 19, 2010 at 9:10 pmI tried that Vince but it still had jagged edges around my graphics and text. I tried some other things and found one that kinda fixed my problem. I rendered it out as a quicktime “graphic” and everything was crisp and clear around the edges BUT it gave the video this very bad grainy look. I am about to give up man.
Vince Becquiot
April 19, 2010 at 9:17 pmMitch,
Could it be an issue with the footage not being interpreted correctly from After Effects to Premiere?
Are you working inside a square pixel comp in AE? What is is interpreted as in Premiere?
Vince Becquiot
Kaptis Studios
Jon Barrie
April 19, 2010 at 11:29 pmCould you post a screen grab so we can see it?
It might help us clarify what’s happening if you could show the original and the final.Jon Barrie
aJBprods
http://www.jonbarrie.net
http://www.suiteskills.com -
Jeff Brown
April 20, 2010 at 1:25 pm
