Activity › Forums › Adobe Premiere Pro › Jagged edges in premiere pro cs4
Mitch Hardison replied 16 years, 5 months ago 5 Members · 16 Replies
Mitch Hardison
April 20, 2010 at 1:41 pmI found “show movie properties” but it is grayed out in my version of quicktime. It is only for the pro version. I am going to try and see what my comp settings are in AE and then what premiere is interpreting the footage as like Vince said. I am also going to try and post some screen shots. One other thing I noticed was that the file coming from AE is 2.13 gb and then the same file rendered out in premiere at the highest quality (i thought) is only 320mb. Premiere is compressing it but I can’t figure out why. I will try and post some screen shots and give you guys a better idea of what is going on. Thanks so much for you help
-Mitch
Mitch Hardison
April 20, 2010 at 8:20 pmMy After Effects project is D1/DV NTSC widescreen (1.21)
Premiere is:
General
Editing mode: QuickTime DV NTSC
Timebase: 29.97fpsVideo Settings
Frame size: 720h 480v (1.2121)
Frame rate: 29.97 frames/second
Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2121)
Fields: Lower Field First
Jacob Goodnight
April 21, 2010 at 9:19 pmif QT is scaling your video at all for playback it will screw up graphics like that too. I know when I export something from FCP that is DV, if I watch it in QT it usually looks like crap but, if I export from QT as a .m4v or another format for web, it will look fine again. What is the final output for the video you are working on? You might try taking it to the next step and see how it looks there…
Jacob Goodnight
April 22, 2010 at 2:07 amyou could also try importing the clip back into premier pro and see if it looks right in there at 100% scale. If it looks good, you don’t need to worry about how it looks in QT…
Jeff Brown
April 22, 2010 at 1:29 pmFYI, I’ve found QT pro to be well worth the few dollars. It’s a very handy utility to do quick audio conversions, for one.
-Jeff
Mitch Hardison
April 23, 2010 at 3:08 amI finally figured out my problem. I made my project in After Effects 864×480 24p and rendered it out as a .mov. Then I used the exact same settings in premiere and the file came out perfect. Before I was using 29.97 720×480 and for some reason premiere did not like it I guess. Thanks a lot for all your help guys, especially Vince because he said that could be my problem from the begging. I will probably not film or make a project in 29.97 again. Thanks again- Mitch
