Activity › Forums › Adobe After Effects › Jagged edges in my video!
  • Jagged edges in my video!
    Posted by Marcus Simmons on October 7, 2008 at 7:11 pm
    Hello, all!
    MSDesign here, and I’m new to the creative cow scene… so I’m sorry if I sound like a n00b.
    1. After capturing my video, I noticed that there were jagged edges in my video (i.e. at the edge of objects in the scene). Is there any way to fix this in Adobe After Effects?
    – If this is already covered, please point me in the direction of the correct forum, thanks.-
    2. I would like to know what is the most effective method of color correction in AE. Most of the methods I’ve found are quite tedious.
    3. Someone please tell me the importance of a “Cineon Sequence”!
    Thanks for all of the help in advance!
    MSDesign
    Why was there Baaaacon in the soap?!!!
    Don Morley replied 17 years, 4 months ago 3 Members · 5 Replies
  • Chris Wright
    October 8, 2008 at 12:20 am
    In the immortal words of Tom Cruise, “Help me, help you.” What did you capture with? fps, interlaced? resolution, bitrate, chrominance, alpha, etc…?
    Many people use Color Finesse because it doesn’t have the 8bpc bottleneck a lot of the cheap solutions use.
    Cineon sequences are individual images that use log based luminance to store color in 32bpc, good enough for working with film based 35mm color correction.
  • Marcus Simmons
    October 9, 2008 at 1:26 am
    Hardware: Panasonic dvx100…something
    FPS: 24
    I/P: Progressive
    Capture software: Final Cut Pro
    Resolution: 720×480
    Sorry for sounding soo n00bish, but I have no Idea of the chrominance or alpha… maybe you could show me how to check that? Thanks!!
    I did hear something about color Finesse, but not much. I will definately check that out!!
    I appreciate you very much, sir!!!
  • Don Morley
    May 15, 2009 at 11:39 pm
    I have jagged edges on my video.
    I shot with the Panasonic HPX500, P2 Card. NTSC 720×480 progressive.
    I open the xml footage in After Effects CS4 and there are jagged edges on diagonal lines in the video.
    I know the footage is good, becauase I also have Premiere Pro CS3, it handles the same footage great. Looks fine.
    Whats up with After Effects? Why would it do this? I mave checked my composition settings, can’t find anythin amiss.
    Please help.
    Don Morley
  • Chris Wright
    May 16, 2009 at 12:09 am
    make sure AE has interpret footage set correctly, pulldown, interlaced off, etc. and the preview aspect correction button in the comp is turned off.
  • Don Morley
    May 16, 2009 at 12:26 am
    Chris,
    Beautiful! It sharpened right up. I’m exporting my clip now to compare to previous version.
    Many, Many Thanks!
    Don Morley
