Activity › Forums › Apple Final Cut Pro Legacy › jagged edges in motion stills
  • jagged edges in motion stills
    Posted by Jack Entonces on December 4, 2006 at 2:37 am
    I imported .bmp file into FCP.
    I used some motion keyframes to give it movement.
    When I played it back, the movement is choppy and the
    picture has jagged edges.
    When I stop the clip, the picture is very clear,sharp.
    It’s only when it moves that it is fuzzy and jagged.
    I’m viewing on an NTSC t.v. monitor.
    Is there a fix for this?
    thank you
    Tyler Grutsch replied 15 years, 4 months ago 5 Members · 4 Replies
  • Chris Poisson
    December 4, 2006 at 4:38 am
    This issue has to be one of the most if not THE most asked questions here, I used “stills” as a search word, you could also try “flickering.”
    https://forums.creativecow.net/cgi-bin/new_search_engine.cgi
  • Tom Matthies
    December 4, 2006 at 2:20 pm
    Render your effects?
    Tom
  • Chris Borjis
    December 4, 2006 at 6:08 pm
    one thing to be sure, check that all of your graphics are at or near D1 resolution. FCP doesn’t seem to be able to scale images with bicubic quality which is completely absurd.
  • Tyler Grutsch
    June 2, 2011 at 11:39 pm
    In the motion setting under crop, I changed the feather to give it a softer edge. I realize this is just a quick fix and probably not a solution, but I was under deadline and it worked for me.
