Activity Forums Apple Final Cut Pro Legacy Jagged edges in eps file in FCP 7
  • Jagged edges in eps file in FCP 7
    Posted by Alyssa Grinberg on January 23, 2015 at 8:53 pm
    I have an eps file and I am trying to bring it into FCP 7 but the edges look jagged. I have tried a number of different things and nothing seems to work…
    –I started with the file in illustrator and saved for web as a png file
    –I have saved the file in photoshop, saved for web as a png file
    –I have adjusted the size down in FCP 7 but still the same issue
    –I have pulled the file into compressor after it’s been saved as a png
    –I have put the file into motion and exported as an mov file. It looks good there, but when I pull it into FCP I have the same issue. This leads me to believe it’s a FCP issue
    I have not had this issue with other files and would really appreciate any help. I have run out of creative solutions.
    Alyssa Grinberg replied 11 years, 7 months ago 3 Members · 6 Replies
  • Shane Ross
    January 23, 2015 at 9:57 pm
    What are the sequence settings?
    Shane
    Little Frog Post
  • Alyssa Grinberg
    January 26, 2015 at 3:25 pm
    Thanks for your reply Dave. The Field Dominance column is all set to none. So, I don’t think that’s the issue. Still trying to sort it out.
  • Alyssa Grinberg
    January 26, 2015 at 3:31 pm
    Apple ProRes 422 1920×1080 24p 48 kHz
    The settings for the clip can be viewed here: https://www.dropbox.com/s/qdia9r0pswu2czg/Screen%20Shot%202015-01-26%20at%2010.28.47%20AM.png?dl=0
    Thank you so much for taking a look at this. I really appreciate it!
  • Alyssa Grinberg
    January 26, 2015 at 5:22 pm
    I see that alpha is set to straight for this .png but for the other .png files that don’t seem to have issue it’s set to white. Do you think this could be it?
  • Daryl K davis
    January 26, 2015 at 5:31 pm
    A 634 x 182 resolution still file is pretty small for a 1920 x 1080 sequence. Is it intended to fill the frame and/or what percentage are you enlarging it?
    DK Davis / Editor/ Post Super
  • Alyssa Grinberg
    January 26, 2015 at 5:32 pm
    I have tried with a much larger file size, and it still shows the jagged edges. I have tried it at 100% and also reduced down and still the same issue.
