Activity › Forums › Adobe After Effects Expressions › Jack in the box in Z axis only
  • Eric Sanderson
    October 27, 2008 at 4:44 pm
    freq = 5;
    amp = 125;
    decay = 3;
    z = amp*Math.cos(freq*time*2*Math.PI)/Math.exp(decay*time);
    value + [0,0,z]
    theres a few ways to do it, none any more simple than the other, heres one…and this is assuming your doing a Math.sin or .cos*Math.exp(time) expression for the spring action.
  • Göran Thorén
    October 27, 2008 at 4:56 pm
    Hi Eric and thank´s a million for that solution!
    Even if I can`t keyframe it, it will work great for my needs!
    Do you have a clever suggestion for animating it to? (think of holding an object in your hand and looking down and dropping it)
  • Eric Sanderson
    October 27, 2008 at 4:58 pm
    you shouldnt need a script if you planned on keyframing it.
    So if im understanding you right you dont need so much of a “springy” action as you do just bounce or recoil from something dropping and hitting the ground?
  • Göran Thorén
    October 27, 2008 at 5:09 pm
    What i mean is if I need to drop a lot of objects that way and have it do that springy motion when it lands.
    Another thing. Is there a way to offset your expression so #1, it doesn´t start right away and #2 so the layers doesn´t move in synch?
    Thank´s again!
