Activity › Forums › Apple Final Cut Pro Legacy › J30 digibeta deck not seen by FCP
  • Michael Garber
    February 16, 2006 at 11:46 pm
    I happen to be using a J30 today. When I turned it on, it was in 625 PAL mode. Had to change it to 525. Could that be the problem? Otherwise, I have had no problems. It’s a good little deck.
  • Paul Dickin
    February 17, 2006 at 11:02 am
    Hi
    I’ve had this when I’ve tried to use the J-30 FW at the same time as having three FW400 drives daisy-chained to the other FW port on a G4MDD.
    As soon as I disconnected the third FW drive everything worked again…
    It was a generic FW drive-case with a Prolific bridge board, which must have caused an identity clash on the FW bus with the J-30.
