Activity › Forums › Adobe Premiere Pro › Izotope RX as plugin?
  • David Cherniack
    July 8, 2011 at 3:28 pm
    In theory PrPro supports 64 bit VST. In practice very few plugins work. This is a limitation in how PrPro presently supports VST. Hopefully that will change for the better.
    There are two solutions:
    If you have CS5.5 and Audition you can use RX VSTs there with dynamic linking.
    I prefer to do the following as it’s normally faster and doesn’t require Audition:
    – set the RX standalone app as the default for wav files (on Windows, I don’t know how on Macs)
    – render and replace the audio clip on the timeline (this may require first unlinking if it’s part of a video file)
    – then from the new clips context menu select edit original. This loads the clip in the RX app. After I do my RX work I save the file. PrPro writes the new file wave form data and replaces the clip on the timeline.
    David
    AllinOneFilms.com
  • Theo Van laar
    July 8, 2011 at 9:27 pm
    Hi David,
    I also prefer your second solution. That’s exactly the way we use Izotope in Vegas. However, I must be blind or so because there is no way I can find where to change the setting for audio editor from Audition or Soundbooth to Izotope. Where can I make this change?
    Theo
  • David Cherniack
    July 9, 2011 at 11:53 am
    Hi Theo,
    If you are on Windows you have to associate wav files with the Rx app so “edit original” will open the file in Rx. In Start do a search for “associations” and that will take you there. If you are on a Mac someone else will have to tell you.
    David
    AllinOneFilms.com
  • Theo Van laar
    July 10, 2011 at 8:58 am
    Hi David,
    Thanks for your reply.
    I am working on Windows 7 and PPro CS5. When I do a Windows search for associations, I get no hits. So the folder might be a hidden folder?
    When I search the Adsobe Community Help for associations, I also get no hit. Sorry, but apparently I’m doing something wrong!
    I can ony find an associations option in Bridge. Do I have to set the change in Bridge to get it to work in Premiere?
    If not, can you give some more details on where to find this option?
    Thanks again for your patience and help
    Theo
  • David Cherniack
    July 10, 2011 at 10:34 am
    Hey Theo,
    OK try this route to it:
    Start::Control Panel::Programs::Make a File Type always open in a Specific Program
    Wait for the list to appear. Scroll down to .wav and double click on it. Browse to the IzotopeRx application and select it.
    Hope this does the trick.
    David
    AllinOneFilms.com
  • Theo Van laar
    July 11, 2011 at 12:33 am
    Ah, this is how you do it. So it is not a function within PPro? Anyway, I will try it your way.
    Thanks for your time!
    Theo
  • Alexey Lukin
    July 11, 2011 at 4:13 am
    RX 2.01 has been patched for compatibility with Premiere CS5. You should be able to run the plug-in.
  • Theo Van laar
    July 11, 2011 at 12:28 pm
    Thanks. I have patch 2.01, but where do you find the plug-in in PPro CS5? Is it hidden somewhere? I have been looking everywhere, but I can’t find it.
    Theo
  • David Cherniack
    July 11, 2011 at 1:20 pm
    64 bit VST plugins need to be installed into c:program filesSteinbergVstplugins
    PremierePro by default checks that directory on loading. If a new plugin is found to be compatible it will be listed in the Effects panel under Audio Effects. and when you apply it to an audio clip it’s controls will be in the Effects Control Panel.
    David
    AllinOneFilms.com
  • Theo Van laar
    July 11, 2011 at 2:12 pm
    OK, thanks. Izotope RX is not found there at this moment, but at least now I know where to place them.
    Theo
