Activity Forums VEGAS Pro IVTC Film and PAL
  • Ole Kristiansen
    December 8, 2019 at 10:40 pm
    Your camera has 2 different system frequencies! NTSC 60Hz and PAL 50Hz! You have chosen PAL 50Hz – because you live in a country where you use 50Hz !
    Now you set your camera to PAL video mode/system frequency ! in PAL video mode – you can record 24fps it is 24Hz and 25, 50fps named PAL !
    If you like the look of 24fps – then use it – Vegas will not list it as PAL because it is 24Hz !
  • John Williams
    December 8, 2019 at 10:58 pm
    Hi Ole
    Thanks for your patience -:).
    “If you like the look of 24fps – then use it – Vegas will not list it as PAL because it is 24Hz ”
    OK
    J
  • Francois Pénzes
    December 8, 2019 at 11:00 pm
    Hi John
    NTSC stand for National Television System Committee and this system is used in countries that have an electrical grid that is supplied with 120V at 60Hz. (see this link for the list of countries that use NTSC) Frame rate is typically 29.97 fps. (half of 60Hz) and multiples of it.
    https://en.wikipedia.org/wiki/NTSC
    PAL stands for Phase Alternating Line and this system is used in countries that have an electrical grid that is supplied with 220V at 50Hz. (see this link for the list of countries that use PAL) Frame rate is typically 25 fps. (half of 50Hz) and multiples of it.
    https://en.wikipedia.org/wiki/PAL
    Now, what about 24 fps. That is a whole different story. It was for the longest time the standard for film. Best you read these very well written articles about the history of it on top of the one recommended by Mike Kujbida.
    https://www.filmindependent.org/blog/hacking-film-24-frames-per-second/
    https://aframe.com/blog/2013/07/a-beginners-guide-to-frame-rates/
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
Page 3 of 3
