John Williams
December 8, 2019 at 8:07 pmmy video mode is set PAL and my frame rate is set to 24 fps
John Williams
December 8, 2019 at 8:21 pmi just shot a few seconds now. Video mode is PAL. fp is 24. on loading to vegas 15 it give is at ivct
I change to start all projects with 24PAL but it goes back to IVTC Film when opened again -
Ole Kristiansen
December 8, 2019 at 8:28 pmHi John
“Video mode is PAL. fp is 24” That is wrong – 24fps is not PAL – 25, 50fps is PAL !
Please tell me why you set your camera to record 24fps ?
John Williams
December 8, 2019 at 8:36 pmthere is a 24 fps option under PAL in my camera
When i say start all projecs with these settings it does not keep the setting when closed and started again. Have to change every time
Ole Kristiansen
December 8, 2019 at 8:47 pm“there is a 24 fps option under PAL in my camera” Yes – 24fps is cinema mode – 25, 50 fps is PAL !
If you look in the manual for your camera – you also need the 24fps cinema – 25, 50fps PAL mode if you connect your camera to a PAL tv !
But still 24fps is not PAL – is is just the way Nikon have made your camera menu ! If you want PAL set the fps to 25 or 50 !
John Williams
December 8, 2019 at 8:56 pm@Ole Kristiansen
Thanks. What is cinema mode is that NTSC.? . I will set the camera to 25 and see what happens thank you. Strange to put an
NTSC option under PAL in the menu -
Ole Kristiansen
December 8, 2019 at 9:18 pmHi John
“What is cinema mode is that NTSC.? No, cinema mode on your camera is 24fps !
Your camera can be used in NTSC 60Hz countries and in PAL 50Hz countries ! In the NTSC mode 24fps, 30, 60fps ! In the PAL mode 24fps, 25, 50fps !
You got a 24fps “cinema look” in NTSC and PAL video mode – so if you want to see 24fps on a PAL tv – you need to record in PAL video mode – if you want to see 24fps on a NTSC tv – you need to record in NTSC video mode !
John Williams
December 8, 2019 at 9:27 pmIn the PAL mode 24fps, 25, 50fps !
But you said PAL does not do 24fps.
“In the PAL mode 24fps, 25, 50fps !” when i do that vegas says ivct which is ntsc
“if you want to see 24fps on a PAL tv – you need to record in PAL video mode” you also said “need the 24fps cinema – 25, 50fps PAL mode if you connect your camera to a PAL tv !”
I do not understand.
I want cinema mode 24 fps in pal
but vegas to say fps 24 pal is ivct which is ntsc not pal.
Ole Kristiansen
December 8, 2019 at 9:50 pmHi John !
Your camera can be used in both NTSC and PAL countries! 24fps is not PAL and PAL is not 24fps! Whether you use NTSC video mode or PAL video mode – you also have the option of recording 24fps which is cinema mode! Why Nikon made it this way – only Nikon can answer!
“I want cinema mode 24 fps in pal” There is no PAL 24fps – PAL is 25, 50fps !
I try again – In PAL video mode – you can record cinema 24fps and PAL 25, 50 fps ! Then you can connect your camera to a PAL tv and play cinema 24fps recordings and PAL 25, 50fps recordings !
If you live in USA you need to set to NTSC video mode – then you can record cinema 24fps and NTSC 30, 60fps ! If you connect you camera to a NTSC tv – you can play cinema 24fps, and NTSC 30 , 60fps recordings !
John Williams
December 8, 2019 at 10:14 pmHi Ole
Thanks i appreciate it but i do not understand at all!
“you also have the option of recording 24fps which is cinema mode!” so is this NTSC?
What I should have said in OP is that it is cinema mode 24 fps that vegas says is ivct
I wanted cinema mode because i like that look
Thanks again !
