Activity › Forums › DaVinci Resolve › I’ve never seen this error message . . . have you?
  • I’ve never seen this error message . . . have you?
    Posted by Perry Trest on May 19, 2013 at 3:24 am
    Ran into a never before seen issue while exporting 5K RED clips to ProRes 422 LT using Resolve 9.1.3lite.019.
    During export as one clip finishes processing and another begins, I get the following error:
    Error occurred while closing clip ‘/Volumes/MediaDrive/XcodesFolder/A003_C001_05166Q.mov’ using QTDecoder.
    Resolve continues to export the files regardless of the error and the transcoded ProRes files open and play correctly in QT and FCP, so no harm as far as I can tell. I guess we’ll find out on the day of conform and color.
    Any clues as to what may be causing this error?
    Thank you in advance.
    Perry Trest
    POSTDIGITAL, Inc.
    Davinci Resolve 9 Licensed
    MacPro 12core 2.66Ghz
    20GB RAM
    Slot 1 = ATI 5770
    Slot 2 = Quadro 4000
    Slot 3 = DeckLink SDI
    Slot 4 = Nitris DX HIC
    Internal 6TB soft RAID-0
    Euphonix Artist Color
    Flanders Scientific CM170W
    Davinci Resolve 9 Lite
    iMac 27″ 2.7GHz Quadcore i5
    20GB RAM
    Blackmagic Mini Monitor
    Blackmagic HDLink Displayport
    HP Dreamcolor
    Joseph Owens replied 13 years, 4 months ago 2 Members · 1 Reply
  • Joseph Owens
    May 20, 2013 at 1:18 pm
    It may be an Apple quirk, since the 5K resolution setting may violate what Quicktime considers to be “optimized”, similar to the kvetching that FCP often does when you import ProRes files. FCP7 may be a non-starter for 5K anyway, but it was certainly a surprise to me that even an 853×480 ProRes clip would trigger an ” Out of Memory” baulk.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
