Activity › Forums › Apple Final Cut Pro Legacy › I’ve been staring at the FS2 box for weeks now.
Mark Maness replied 19 years, 3 months ago 9 Members · 11 Replies
Mark Maness
May 29, 2007 at 1:39 pmSomething to keep in mind, guys….
Apple’s ProRes 422 is AWESOME!
BUT, if you have been working in a format like DVCProHD or another high compression format, ProRes 422 does cost you much more drive space than you are used to using. If you are already an editor using Uncompressed 8-bit or 10-bit, then the transition will be very painless and easy.
Do some tests, manage your media and play with it before you start a project that uses ProRes entirely.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey
