Activity › Forums › Adobe After Effects › Its possible to open AE CS5 project in AE CS4?
Posted by Michal Bronec on June 20, 2013 at 2:37 pmI have a small project created in AE CS5 and I need to open in in CS4. Is there a way how do it?
Michal Bronec replied 13 years, 3 months ago 3 Members · 4 Replies -
Michal Bronec
June 20, 2013 at 2:50 pmIt seems, it can be done, but AE CS5 or higher is needed.
https://churchmediadesign.tv/make-after-effects-files-backwards-compatable/
Does anybody have CS5 or higher version with this capability? Would be somebody so kind and convert it this project for me? 🙂 Its very small. -
Cassius Marques
June 20, 2013 at 2:50 pmShort answer: no.
Long answer: If I’m not mistaken, backwards compability only works for CS5.5 to CS5 and up.
Your last option would be to try this script (costs some $). Though you’ll still need access to CS5 for the export part.
John Cuevas
June 20, 2013 at 2:56 pmYou could download a trial of CS6 of the CC version. Download Trial
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Michal Bronec
June 20, 2013 at 3:02 pmThe problem is I am not on 32bit PC right now 🙁 So I cant use CS5 or higher.
