Activity Forums VEGAS Pro Its possible to capture only audio via fireware?
  • Its possible to capture only audio via fireware?
    Posted by Petr Berger on February 14, 2010 at 5:21 pm
    I’m recording voiceovers to camera sometimes and it would be much better if I could capture only audio via firewire. Is this possible?
    Petr Berger replied 16 years, 7 months ago 3 Members · 3 Replies
  • John Rofrano
    February 14, 2010 at 6:50 pm
    It’s not possible to only capture the audio without the video. The best you can do is to use the Vegas capture program and use your camera mic live. It’s nowhere near as convenient as using a real audio interface and recording directly into a track. If you do voice-overs, you really should consider buying a professional sound card. Even a USB mic like the AT2020USB would be good for this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edward Troxel
    February 14, 2010 at 8:28 pm
    Using Scenalyzer Live, you can capture audio only via firewire.
    Edward Troxel
    JETDV Scripts
  • Petr Berger
    February 14, 2010 at 8:35 pm
    I know. Its just a temporary solution. Thanks.
