Activity Forums Adobe After Effects Its fall and clients want falling leaves
  • Its fall and clients want falling leaves
    Posted by Mike Schrengohst on October 27, 2005 at 10:12 pm
    Its fall and clients want falling leaves. I have 5 nice photos of autumn leaves. Is there a plug-in or effect that will clone my leaves? I have tried making different comps to add more layers but I am still keyfaming every leaf.
    Graham Quince replied 20 years, 11 months ago 5 Members · 5 Replies
  • Phil
    October 27, 2005 at 10:13 pm
    Trapcode particular 🙂
    if you have combustion, there is a preset for falling leaves particles, i used that preset in our last spot.
  • Jim Zito
    October 27, 2005 at 10:30 pm
    If you don’t have Trapcode and don’t wanna spend the money, I think Particle Playground would work too. Just set the layer map to one of your leaves and adjust the random settings accordingly.
    HTH
  • Mike Schrengohst
    October 27, 2005 at 11:53 pm
    Using AE, will look at Particle Playground.
  • Michael Duff
    October 28, 2005 at 1:54 am
    try using the shatter. Use a custom shape so that your leaves are each a piece. Play with where the camera sits and change the gravity direction to get the desired look. It can look pretty good and I think will be less render heavy than PP…..maybe someone can expand on the finer details of doing it this way
    Michael Duff –
    Southern Cross Ten, Australia
  • Graham Quince
    October 28, 2005 at 2:03 pm
    Ayato’s got a pretty good falling petals tutorial, i’m sure you could adapt it.
    Graham
    http://www.qcit.com
