Activity Forums Adobe After Effects Iterating a composition
  • Iterating a composition
    Posted by Nikolya Gousteau on May 27, 2012 at 7:55 am
    Hi all,
    It is known that one cannot nest a composition into itself. But I would like to do a slightly different thing.
    I have a composition, and I would like to add a “previous frame of the composition” to itself as a layer.
    Is this possible?
    You can think of this also the following way. First of all, we arrange each frame of the comp as a still layer. (Layer “Frame N” should be on top of layer “Frame N-1”.) And then, as time goes by, we subsequently turn each of these layers on. Maybe this can be done using expressions, but I suppose there might be even better way…
    Thank you in advance
    Nikolya Gousteau replied 14 years, 4 months ago 2 Members · 2 Replies
  • Erik Waluska
    May 28, 2012 at 4:30 pm
    I’m not sure exactly what you’re trying to accomplish but could you use the Echo effect on an adjustment layer?
  • Nikolya Gousteau
    May 29, 2012 at 12:44 pm
    Thank you a lot, Erik! Echo does almost exactly what I wanted!
