Activity Forums Boris FX Particle Illusion It keeps repeating
  • It keeps repeating
    Posted by Myri560 on May 2, 2007 at 12:51 am
    In this video I am editing, a certain part just keeps repeating over and over and it won’t let me go past that part that it repeats.
    How do I take this “repeating” off?
    Paul Hansen replied 19 years, 4 months ago 3 Members · 2 Replies
  • Elvis Deane
    May 2, 2007 at 5:30 pm
    The playback control bar has three boxes with numbers in them. The first is the Current frame, and the next two set the range of the scene. There’s a Loop button between those two boxes, and when it’s pressed down, the scene will loop between those two frame numbers.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Paul Hansen
    May 4, 2007 at 3:33 am
    And, I suspect you haven’t changed the number of frames in the little upper right hand white window that lists the default # of frames for the video. Change it to the number of frames in the video you want to which you want to add effects.
