Activity › Forums › Adobe After Effects › It is really slow when I adjust berzier handle on the viewer.
  • It is really slow when I adjust berzier handle on the viewer.
    Posted by Chang hun Kim on July 13, 2009 at 4:30 pm
    I recently upgraded my pc to core 2 quad Q9650 3.0 GHz and ATI FirePro V5700. It is working on Vista 64bit Ultimate with 8 GB memory.
    And also upgraded AE version from CS3 to CS4.
    At first, It was so slow when I moved a key frame on the timeline window, but I got an answer by turning off “Enable Open GL” on the preference. But still it is very slow when I adjust berzier handle on the viewer window and size up and down display size, for example from 100% to 50%, it’s like frozen a second. I turn on “Render Multiple Frames Simultaneously” and leave 0.5 GB RAM for other applications. It is same slow whether I turn on and off that option.
    It is pain in the neck when I do key frame animation. I do many times adjust berzier handle to test animation. This kind of weird performance makes work very slow.
    Any help would be very appreciated.
    Chang hun Kim replied 17 years, 2 months ago 2 Members · 5 Replies
  • Adolfo Rozenfeld
    July 13, 2009 at 5:08 pm
    Looks like a problem with the graphics card driver.
    Try to update the driver to a newer version, and if it doesn’t help, try the opposite – switch to an older version of the driver.
    Adolfo Rozenfeld · Adobe
  • Chang hun Kim
    July 13, 2009 at 7:04 pm
    I tried to downgrade driver version but I can’t.
    After I installed older version of graphic driver, I see it is installed on Device Manager with a notice icon. But it says no driver is installed on display settings menu. So I tried to install manually, but it says “newest version of driver is already installed.”
    I don’t know how to figure out this problem. I just came back to newest version of graphic driver. And still has a problem with AE CS4.
    I bought Firepro V5700 because many benchmarks say that Firepro series are much better than Quadro series for Maya.
  • Chang hun Kim
    July 13, 2009 at 7:26 pm
    I just got a crash information about displaying motion path.
    When I turned off motion path display, it was working well, but I can’t do key frame animation without seeing a motion path.
    some one has an idea about it?
    any help would be appreciated.
  • Adolfo Rozenfeld
    July 13, 2009 at 8:53 pm
    Do you have “Hardware Accelerate Composition, Layer and Footage panels” turned on in Preferences > Display?
  • Chang hun Kim
    July 13, 2009 at 9:26 pm
    I do turn on “Hardware Accelerate Composition, Layer and Footage panels”. But it is still same. Only it is working smoothly when I set “no motion path” on display tap.
