Activity › Forums › Adobe After Effects › It crashes when rendering!!
  • It crashes when rendering!!
    Posted by Alfredo on July 21, 2006 at 2:36 pm
    Hi there,
    Im running AE 6.5 Pro on Windows xp Pro.
    The problem is that After Effects crashes everytime I try to render a quicktime movie, (I use Avid dv codec).
    It works fine if I use another format like windows for media, but it just seems not to like the quiktime movie?? I did reinstall the software but to no avail, sigh!
    any suggestions would be really appreciated,
    many thanks,
    alfredo
    Rhett Robinson replied 20 years, 2 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    July 21, 2006 at 2:44 pm
    [alfredo] “I did reinstall the software but to no avail, sigh!”
    Ensure that you have the latest QuickTime and the Avid DV CODEC installed. Also, try rendering to another QT CODEC to see if this will work. If all else fails and time is an issue, then use the QT DV CODEC. ANd if that also fails, then use TGA sequences. They play fine on NLEs.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com
    customizable animated backdrops with Adobe After Effects project files
  • Rhett Robinson
    July 21, 2006 at 4:28 pm
    I’ll second the above… when you’re having difficulty, render to a compatible image sequence (you may want to ask the person who’s going to receive the file)… Just as AE will load it right up, so will most NLE programs, and I’ve never had a TV station complain at all (I usually give them several formats though, so no matter what I’m covered)
    Good Luck!
