Activity Forums Adobe Premiere Pro Issues with PPro CS6
  • Issues with PPro CS6
    Posted by Itamar Kool on July 25, 2012 at 9:55 am
    A while ago I switched from FCP7 to Premiere, like so many others. Recently I also upgraded to CS6. I mostly work with AVCHD files. At the moment I am working on a documentary. It involves a lot of AVCHD files and extra mp3 audio files for the interviews which were recorded seperately. I also recently replaced my Kona LHe card for a Blackmagic Intensity Pro, since the Kona LHe does not support CS6 anymore (shame on you AJA!).
    All the time now I have issues. Playback goes badly; stutters a lot even at 1/4 of the resolution. Video monitoring freezes sometimes. All the time the audio goes out of sync. And it is not something that stays the same. Sometimes this goes bad, sometimes something else. It is really very annoying and I do not know where to look for the solution. Only feeling I have is that the project is too heavy for PPro. Can anybody point me to the right direction?
    Kool En De Anderen
    MAC Pro 8 core/OS 10.6.8/BMD Intensity Pro/Apple FCS 3/Adobe Production Premium CS6
    http://www.koolendeanderen.nl
    Craig Ricker replied 13 years, 9 months ago 7 Members · 13 Replies
  • 13 Replies
  • Tero Ahlfors
    July 25, 2012 at 12:25 pm
    Well AVCHD is a resource hog of a codec and you’d be better off making wavs out of the mp3 files.
  • Chris Tompkins
    July 25, 2012 at 12:45 pm
    Agreed, try not to edit with mp3’s, also, saw where Adobe tech guy says 10.6.8 will run CS6 but you have better results with 10.7.x
    FWIW
    Chris Tompkins
    Video Atlanta LLC
  • Tom Daigon
    July 25, 2012 at 12:57 pm
    I know if you want to take advantage of the Adobe Transmit technology with Kona3 , you must be on 10.7. That might be the case with BMD hardware as well.
    Adobe Transmit is…
    https://forums.adobe.com/message/4416937
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Petros Kolyvas
    July 25, 2012 at 1:01 pm
    I was going to suggest the same thing, as well as ask how much RAM you have installed.
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Itamar Kool
    July 25, 2012 at 1:12 pm
    I’ve got 12 gigs of RAM installed and from all the answers I do understand that i am putting a heavy load on both the hard ware and the soft ware. I do not have an Nvidia card installed, so I am not using the Mercury engine. Well, OK, fair enough. Thanks for the reactions
    Kool En De Anderen
  • Petros Kolyvas
    July 25, 2012 at 1:38 pm
    CUDA doesn’t currently accelerate AVCHD decoding, but if you’re applying effects it could ease-up on the CPU. Its not the magic bullet though. I’d try Lion as Tom suggested and go from there. MLion is being released today so if you’ve held off, its time!
  • Itamar Kool
    July 25, 2012 at 2:02 pm
    What exactly does Lion do better then Snow Leopard for PPro? I held back on Lion since it doesn’t support Rosetta anymore
    Kool En De Anderen
  • Chris Borjis
    July 25, 2012 at 4:11 pm
    I have black magic multibridge on one mac (8 core with 16gb of ram and quadro 4000 on both)
    and a decklink studio on the other.
    I’m having no trouble at all with avchd editing (what I mostly work with)
    I’m also running 10.6.8, but I have very fast RAID 5 disk arrays.
    what storage are you using?
    that could be a big part of the problem.
    There are MANY of us still using 10.6.8
    with CS 6 and having no trouble at all.
  • Itamar Kool
    July 25, 2012 at 6:48 pm
    Well, I thought that since AVCHD files are small in comparison to ProRez for example, that your drives didn’t have to be so fast. I am running on an internal SATA drive
    Kool En De Anderen
  • Chris Borjis
    July 25, 2012 at 8:09 pm
    [Itamar Kool] “Well, I thought that since AVCHD files are small in comparison to ProRez for example, that your drives didn’t have to be so fast. I am running on an internal SATA drive”
    the size won’t determine the performance. It’s the decoding for playback and AVCHD is pretty intensive.
    stack a few layers and you’ll hit a performance wall for sure if you’ve only got a single sata storing them.
    If you can do at least a RAID zero setup, I would bet that would help big time.
    Some kind of RAID is pretty much a requirement these days if you want native smooth playback
    with the current camera formats.
