Activity Forums Apple Motion Issues with Motion 2 crashing
  • Issues with Motion 2 crashing
    Posted by Nathan Sterner on July 26, 2007 at 10:18 pm
    So I have a problem with Motion 2 crashing on me. It’s never done it before and I’m pressed for time. Though it should be noted that I only run it on a G4 powerbook with 2 gigs of ram. I know that my lame computer is no doubt the primary reason for the program crashing; however as I said, “it’s never done this before.” I’m fine with lengthy render times etc., I just want it to work a little bit. Does anyone out there have any suggestions on what might prove the best fix? Thanks.
    Edo Medicks replied 19 years, 1 month ago 2 Members · 1 Reply
  • Edo Medicks
    August 8, 2007 at 5:12 pm
    had the same problem.
    lower res for work,save before render, and un-tick the ‘put hard drive to sleep’ in energy pref.
    also, i put my MBP directly on the Air conditioner outlet. ran 46c while render!
    The cup is half full and my shirt is half wet
