Activity › Forums › AJA Video Systems › Issues with: Mackbook Pro, AJA Io and Beta SX
  • Issues with: Mackbook Pro, AJA Io and Beta SX
    Posted by Jim Carswell on August 15, 2006 at 9:56 pm
    I’m brand new to the AJA Io. Loaded the software on my Macbook Pro, hooked up my Beta SX laptop deck to the Io via SDI and RS422 and connected the Io to the Macbook via firewire. All is good at this point.
    I can’t seem to get the computer or Final Cut to recognize the deck. In East Setups I selected: AJA Io- NTSC US SDI A-V 8 Bit uncompressed. A window pops up stating: Unable to locate capture device PRO Io Uncompressed 8 bit 422 video. A second window comes up stating: Computer does not have any serial ports matching those specified by the current device control preset. You will need to set port.
    Under Video and Audio settings my sequence preset is DV NTSC 48khz. The capture preset is AJA Io SDI a/v 8 bit to DV 48khz. The device control I selected is AJA Io RS422 NTSC. For video playback I selected Digital Cinema Display Full Screen (assuming this would mean the laptop’s screen). for audio output I chose Default.
    The lights on the front of the AJA Io box are as follows: Status: Power-green, Firewire-blue, NTSC-blue. Mode: In-blue. Video in: Present- green, SDI- blue. Audio in: Present-green. SDI-blue.
    If any one has suggestions on what I am doing wrong or what I can do differently inorder to get video to the computer… I sure would appreciate it.
    Regards,
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
    Joe Procopio replied 16 years, 4 months ago 3 Members · 3 Replies
  • Jim Carswell
    August 15, 2006 at 11:01 pm
    Hey,
    Hector at AJA came to the rescue with in a matter of minutes and solved my issues. What a great response from AJA.
    Jim
    Jim Carswell
    Savannah, GA
  • Ed Dooley
    August 16, 2006 at 3:16 pm
    Hector got me out of an IO jam recently too. I talked to another person at AJA too, and Hector seemed
    to know his stuff better.
    Ed
  • Joe Procopio
    May 20, 2010 at 3:08 pm
    next time post the fix so if anyone else has the same issue, and pulls this post up, even 4 years later, they will have the answer.
    guess i’ll keep looking
    Broadway Video, NYC
    AVID/FCP editor/engineer
