Activity Forums Blackmagic Design Issues with HDLink and HP L2335
  • Issues with HDLink and HP L2335
    Posted by Sven Hanten on June 9, 2005 at 10:07 am
    we have some problems with the 23″ HP LCD Monitors L2335. Sometimes black frames and sometimes black lines. It looks like a sync problem of the HP display. We changed the HDLink with no result. The same HDLink works on a Apple 23″ display fine.
    When you turn on the HP you see, that the DVI signal of the HDLink is 50Hz and the on screen display shows that 60Hz are recommended. But the HP should be able to show signals at a framerate as low as 47 Hz.
    Bevore we waste time and time to find the error, I want to know, if there are any known issues with the combination of HDLink an HP display?
    Thanks.
    Sven
    Sven Hanten replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
