Activity Forums Blackmagic Design Issues with FCP transitions with BlackMagic
  • Issues with FCP transitions with BlackMagic
    Posted by Scott Gwin on September 24, 2005 at 4:02 am
    When I render dissolves and transitions I’m getting video shifts at the start and end points. The HD footage was shot with Varicam at 24p with some overcranked and captured via Panasonic 1200a through my Decklink HD Pro card with the Blackmagic HD 720p uncompressed 8 bit setup. I’ve used these settings before with great results then during this project I encounter this. The FCP version is 4.5 with a Huge Systems Ultra 320 array.
    I’ve double checked all the settings so any help would be great before I pull all the hair out of my head.
    Scott
    Luke Maslen replied 21 years ago 2 Members · 1 Reply
  • Luke Maslen
    September 26, 2005 at 4:35 am
    Hi Scott,
    If you have not already done so, please update to the DeckLink 4.8.1 drivers as they were specifically tested against the Panasonic 1200a deck and may well overcome your problems. Are you aware of any changes made, since your previous successful configuration, which might explain the current problems?
    Regards,
    Luke Maslen
    Blackmagic Design
