Issues with Deinterlace
I’m trying to make a QuickTime file for the web from a DVD of an HDTV 1080i broadcast. I’ve tried deinterlacing a few different ways but none have fully worked. It ends up looking terrible with traces of interlace.
I’ve tried deinterlacing with MPEG streamclip when converting the file from .VOB to .mov. In Final Cut I’ve tried using the de-interlace filter with both upper and lower field dominance. I’ve tried using the shift fields filter on it’s own and along with the deinterlace filter in all possible combinations. Does anyone have a suggestion?
Here’s info for the file in case it helps:
uncompressed 8-bit 4:2:2, 1920×1080, 29.97 FPS
