Issues using Keylight and Advanced spill suppressor with Alexa C-Log footage 32 bpc in After effects 2018 CC
Hi all,
I’m working in a project for a TV series doing some screen replacement with Alexa footage. When I have the comp ready, I deliver the file to do color grading. I’ve tried for the first time a new workflow, but Advanced spill suppressor is not working properly. Let me tell you the steps I’m following.
1. I turn on Color management, and I select HDTV (rec. 709) wich is the final colorspace. I also work in 32 bpc.
2. I import the Alexa footage, and I assign it the profile ARRI LogC3 Wide Color Gamut – EI800 (wich is the one used on set)
3. Do the comp.
4. Render a Quicktime DNxHR 444 10 bits and in the Color Management tab I also select as the output profile: ARRI LogC3 Wide Color Gamut -EI800.When I try to do some keying and use the advanced spill supressor I find some artifacts. The main problems with keylight come with areas with heavy motion blur.
I suppose it is because I am getting colors up than 1,000 (as you can see in the attached pictures), because when I use Curves (for example) to reduce the exposure everything is working fine.
I wonder if there’s a way to work this way. Or maybe I have to do the keying without assigning the profile ans using it as a matte for the footage, but then again I’ve got the spill problem.This is the first time I use this workflow. I used to comp everything without worrying about color management, just working with the flat footage giving me by default in After effects when importing.
I’m trying to know if there’s a better way of doing things. Any information will be really appreciated.
Thank you so much!!!
