Activity Forums Adobe Premiere Pro Issues regarding timecode when I pause playback
  • Issues regarding timecode when I pause playback
    Posted by Darren Monk on January 22, 2018 at 8:04 pm
    Hello,
    I have asked this before and have a really hard time explaining the issue. I have therefore made a video, please check it out at the following link, then come back here and read my problem – hopefully it’ll make sense then ☺
    On this video please pause at 16 seconds and observe the two timecode numbers – the burned in one on the preview above the smiley face and the one that is in the timeline timecode box near the bottom left of the screen.
    https://youtu.be/bZAxTERJy_o
    Okay, so my issue is that occasionally when I pause playback in Premier Pro the preview window will stop at a certain timecode – in this case at 16 seconds the burned in timecode on the preview window is 01:04:05:22 while the timecode box on the timeline is 01:04:05:21. All I’ve done in the video is paused at the end of some dialogue (muted for confidentiality reasons).
    Then two seconds later, at 18 seconds, you can see the media in the preview window “skip” back a frame so that the burned in timecode then says 01:04:05:21 to match the timeline box timecode.
    This happens around 50% of the time when I pause the media. You can see throughout the video I routinely pause, click on and off the Premier screen, then resume. Sometimes the timecodes match – sometimes they don’t.
    I can’t for the life of me figure out why this happens. A company I work for sends me these videos to make CCSLs with so I need to play/pause constantly. I need the timecodes to be 100% accurate and they cannot be if the preview window stops on X then half the time jumps back to X-1 frame.
    Please – please, someone help me figure out what is causing this.
    The videos are sent as MP4s at 1920×1080.
    My computer is as follows:
    Intel(R) Core(TM) i7-6700k CPU @ 4.00GHz 4.00GHz
    16GB RAM
    Windows 10 64Bit
    I have a Nvidea 1080
    uhh, ask if you want to know anything else, spec wise.
    Robert Withers replied 8 years, 8 months ago 2 Members · 1 Reply
