Activity Forums Maxon Cinema 4D Issue with texture on text extrude
  • Issue with texture on text extrude
    Posted by Kasper Nyman on April 14, 2011 at 11:51 am
    Hey
    I have this problem that when I put textures on my text, which is extruded, it only put it on front surface, not all surfaces.
    Ps. Its not converted into a Spline.
    What should I do?
    Kasper
    Kasper Nyman replied 15 years, 5 months ago 2 Members · 2 Replies
  • Michael Szalapski
    April 14, 2011 at 2:08 pm
    Let me see if I’m following what you’re saying. You have text based off of some sort of spline in an extrude nurb. You apply, for example, a red material. Only the caps of the letters turn red?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kasper Nyman
    April 14, 2011 at 4:32 pm
    Sorry for my bad english, I can understand it might have sounded pretty strange. Here how it is set up on my stage
    I took a text, typed in the word, add the Extrude Nurbs, and then when I apply a texture it seems to only react on caps and front surface. I tried download some pre-made texture, they look great, but one only worked on the extruded surface, and some only worked on front and the caps. I have not convertet it into a Spline (c), should I do that?
    I also used a SUN for light, cause it worked out best for me. Is that a problem also?
    Hope you can help me, or guide me to a place that I can read/see/learn what to do.
    Kasper
    Nyman
