Activity › Forums › Maxon Cinema 4D › Issue with Spline Effector in Mograph
  • Issue with Spline Effector in Mograph
    Posted by Ala Mctoom on September 9, 2011 at 12:49 am
    I have this object that I want to make it spin around. I used a spline path (circle) and applied a spline effector. When the object moves on the spline, it also rotates accordingly.
    My question is simple: how to make it not rotate, and let it always face the Rotation Coordinates I set?
    Ala Mctoom replied 15 years ago 1 Member · 1 Reply
  • Ala Mctoom
    September 9, 2011 at 12:53 am
    Never mind, I found the answer. It’s in the Parameters tap inside the Spline Effector. You just uncheck the rotation option.
