Activity › Forums › Maxon Cinema 4D › Issue with rendering transparent glass
  • Andy Kiernan
    September 1, 2021 at 7:43 am
    the refractive property of the material picks up the BG, whatever is behind it, so you would need to have the ‘green bg’ in the scene but use a tag to hide it (compositing tag in standard/physical) you will then get the glass on alpha but you will see the bg through the glass, so render it on a colour that you will want in your final comp.
