Activity › Forums › Adobe After Effects › Issue with importing image sequence
  • Issue with importing image sequence
    Posted by David Del on July 8, 2008 at 2:36 pm
    I am working on a project that is using a 3D camera. I recently imported an image sequence into the project, but when I place it on the time-line, it does not show up at all in the comp. window. I have turned off all of the eyeballs, solo’d the layer and it is no where to be found.
    I then started a new project and brought it in and there is no issue. I am not sure what the reason is. I am going to have to render out the image sequence in a new comp or should I try to pre-compose the image sequence layer in the comp that is giving me issues?
    Darby Edelen replied 18 years, 2 months ago 3 Members · 5 Replies
  • Todd Morgan
    July 8, 2008 at 4:41 pm
    Not sure what you mean. When you bring the sequence into the timeline does it appear in the layers list? Does the sequence have alpha?
  • Darby Edelen
    July 8, 2008 at 5:16 pm
    Did you set the image sequence as a 3D layer? Are there lights in your composition? If the layer is 3D what is it’s location and what is the camera’s location/point of interest? Is Depth of Field on?
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Del
    July 8, 2008 at 7:19 pm
    I can’t even see a bounding box around the object – so I can’t even zoom out and see it anywhere!
    I have tried to turn it into a 3D layer and I still can’t see it in the comp.
    As I said, even when solo’d, it doesn’t show in the COMP window, but it is VISIBLE in the timeline. Does that make sense?
  • David Del
    July 8, 2008 at 7:20 pm
    And yes, it does have an alpha channel. Forgot to mention that.
  • Darby Edelen
    July 9, 2008 at 1:53 am
    What is your current view? ‘Active Camera’? ‘Front’? ‘Left’?
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
