Activity › Forums › Apple Final Cut Pro Legacy › Issue with Final Cut and HDV on a G5 Quad – Says the codec is missing
  • Issue with Final Cut and HDV on a G5 Quad – Says the codec is missing
    Posted by Robin on May 16, 2006 at 3:47 am
    I’m opening a project I made on a G5 Dual in FCP on a Quad. Says there’s a missing codec. I’m using the latest version of FCP. What the hell?
    Mark Maness replied 20 years, 4 months ago 5 Members · 5 Replies
  • Jeremy Garchow
    May 16, 2006 at 4:00 am
    Sounds like the quad didn’t have FCP correctly installed on it. The installation of FCP includes the HDV codec. Maybe an FCP uninstall and reinstall is in order…unless you used some sort of special codec on your first machine then install that codec.
    Jeremy
  • David Roth weiss
    May 16, 2006 at 4:47 am
    Robin,
    One of the upgrades, possibly 5.03 to 5.04 is known to blow away the HDV codecs on some computers. It happened to a freind of mine when he upgraded, but not to me. He got the codec from another machine and installed it manually. All was fine afterward. So, if you have any friends with FCP just ask them to give you the codec.
    DRW
  • Steve Connor
    May 16, 2006 at 6:38 am
    Otherwise reinstall OSX and FCP that’s what we had to do.
  • Robin
    May 16, 2006 at 10:48 am
    You had to reinstall OSX? That seems a bit dramatic. Did you have to do a complete erase and install or just a simple one?
  • Mark Maness
    May 16, 2006 at 1:30 pm
    Before going that far… Check Apple’s support site for this problem. If I remember correctly, it had something to do with a Quicktime upgrade. You could also do a search here on the Cows. There were several people having this problem a few months ago that I saw in some posts on this forum.
    Did you recently upgrade any software like FCP or Quicktime?
    _______________________________
    Wayne Carey
    Schazam Productions
