Activity Forums Adobe After Effects Expressions Issue with Aligning Keyframes from Multiple Properties to CTI in After Effects
  • Issue with Aligning Keyframes from Multiple Properties to CTI in After Effects
    Posted by Vincenzo Imbimbo on January 13, 2025 at 1:27 pm
    Hi everyone,
    I’m working on an After Effects script that aligns selected keyframes (or layers) to the playhead (Current Time Indicator). While it works well when keyframes are selected from a single property, the script only processes the first property when multiple properties with selected keyframes are involved.
    Here’s the section of the script that handles the keyframe processing:
    // Function to handle sequence arrangement
    arrangeTPH.onClick = function () {
    var comp = app.project.activeItem;
    // Check if the active item is a composition
    if (!(comp && comp instanceof CompItem)) {
    alert("Please select an active composition.");
    return;
    var layers = comp.selectedLayers; // Get the selected layers
    var cti = comp.time; // Current Time Indicator (CTI)
    // Check if there are selected layers or keyframes
    if (layers.length === 0) {
    alert("Please select at least one layer or keyframes.");
    return;
    app.beginUndoGroup("Arrange to Playhead"); // Start undo group
    var keyframesMoved = false; // Flag to check if keyframes were moved
    // Function to process keyframes for a given property
    function processKeyframes(prop, cti) {
    // Skip if the property is not time-varying or has no selected keyframes
    if (!prop.isTimeVarying || prop.selectedKeys.length === 0) {
    return false;
    var selectedKeys = prop.selectedKeys.slice(); // Copy selected keyframe indices
    var firstKeyTime = prop.keyTime(selectedKeys[0]); // Get the time of the first keyframe
    var offset = cti - firstKeyTime; // Calculate the time offset
    var keyframesData = []; // Array to store keyframe data
    // Save data for all selected keyframes
    for (var i = 0; i < selectedKeys.length; i++) {
    var keyIndex = selectedKeys[i];
    keyframesData.push({
    time: prop.keyTime(keyIndex) + offset, // Adjusted keyframe time
    value: prop.keyValue(keyIndex), // Keyframe value
    inEase: prop.keyInTemporalEase(keyIndex), // Temporal ease (in)
    outEase: prop.keyOutTemporalEase(keyIndex), // Temporal ease (out)
    inInterp: prop.keyInInterpolationType(keyIndex), // Interpolation type (in)
    outInterp: prop.keyOutInterpolationType(keyIndex), // Interpolation type (out)
    spatial: prop.propertyValueType === PropertyValueType.TwoD_SPATIAL ||
    prop.propertyValueType === PropertyValueType.ThreeD_SPATIAL ? {
    inTangent: prop.keyInSpatialTangent(keyIndex), // Spatial in-tangent
    outTangent: prop.keyOutSpatialTangent(keyIndex), // Spatial out-tangent
    autoBezier: prop.keySpatialAutoBezier(keyIndex), // Auto Bezier flag
    continuous: prop.keySpatialContinuous(keyIndex), // Continuous spatial flag
    roving: prop.keyRoving(keyIndex) // Roving keyframe flag
    } : null
    // Remove the selected keyframes from the property
    for (var i = selectedKeys.length - 1; i >= 0; i--) {
    prop.removeKey(selectedKeys[i]);
    // Add the new keyframes with updated times
    for (var i = 0; i < keyframesData.length; i++) {
    var data = keyframesData[i];
    var newKeyIndex = prop.addKey(data.time);
    prop.setValueAtKey(newKeyIndex, data.value);
    prop.setInterpolationTypeAtKey(newKeyIndex, data.inInterp, data.outInterp);
    prop.setTemporalEaseAtKey(newKeyIndex, data.inEase, data.outEase);
    // Handle spatial properties if applicable
    if (data.spatial) {
    prop.setSpatialTangentsAtKey(newKeyIndex, data.spatial.inTangent, data.spatial.outTangent);
    prop.setSpatialContinuousAtKey(newKeyIndex, data.spatial.continuous);
    prop.setSpatialAutoBezierAtKey(newKeyIndex, data.spatial.autoBezier);
    prop.setRovingAtKey(newKeyIndex, data.spatial.roving);
    return true;
    // Process all selected layers
    for (var i = 0; i < layers.length; i++) {
    var layer = layers[i];
    var selectedProperties = layer.selectedProperties; // Get selected properties of the layer
    if (selectedProperties && selectedProperties.length > 0) {
    for (var j = 0; j < selectedProperties.length; j++) {
    var prop = selectedProperties[j];
    if (processKeyframes(prop, cti)) {
    keyframesMoved = true;
    // If no keyframes were moved, align selected layers to the playhead
    if (!keyframesMoved) {
    var offset = cti - layer.inPoint; // Calculate time offset for the layer
    layer.startTime += offset; // Adjust the layer's start time
    app.endUndoGroup(); // End undo group
    alert(keyframesMoved ? "Keyframes aligned to the playhead." : "Layers aligned to the playhead.");
    What the script does:
    1. Aligns selected keyframes of a property to the playhead by calculating an offset based on the first keyframe.
    2. If no keyframes are selected, it adjusts the layer’s starTime to align with the playhead.
    The problem: When multiple properties (e.g., Position, Scale, Opacity) are selected with keyframes, the script processes only the first property and ignores the rest.
    What I’ve tried:
    • Iterating over all selectedProperties of a layer.
    • Adding checks to ensure that each property is processed independently.
    Request: Could you help me figure out why only the first property is being processed and how to ensure that all selected properties are included?
    Any advice, corrections, or improvements to the logic are greatly appreciated.
    Thanks in advance! 😊
    Vincenzo Imbimbo replied 1 year, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 13, 2025 at 2:07 pm
    I haven’t tested this at all, but my hunch is that your keyframe processing code changes what’s selected, so you may need to collect the selected properties for all layers before you start manipulating things.
  • Vincenzo Imbimbo
    January 13, 2025 at 10:51 pm
    Hi Dan,
    Thank you so much for your suggestion—it worked perfectly!
    The problem indeed stemmed from the fact that manipulating keyframes was affecting the state of the selected properties. Following your advice, I modified my script to first collect all selected properties and their keyframes before making any changes. By processing the collected data in a separate step, I avoided the issue of altered selections during iteration.
    Thanks again for pointing me in the right direction—it was a game-changer!
