Activity Forums Apple Final Cut Pro issius with luts
  • Vegdo Rjabkov
    November 29, 2017 at 6:48 pm
    thanks alot ???? but why they dont transfer the highlights and the shadows into the lut ?
  • Jeremy Garchow
    November 29, 2017 at 7:15 pm
    [Vegdo Rjabkov] “thanks alot ???? but why they dont transfer the highlights and the shadows into the lut ?”
    It must be the way the data is expressed in the “Basic” section and what can be achieved in a point based LUT.
    The “Tone Map” area has similar controls, and are probably easily mapped to a plot.
    You should contact the LUT exporter developer and see if they have any insight.
    LUTs are not definitive. They are usually a starting point to get footage within the realm of the same look between on set, edit, final grade, and output. Most of the time, they carry grade intention, more so than grade instruction.
  • Vegdo Rjabkov
    November 30, 2017 at 5:25 am
    ok, thanks alot fpr your help :)!!!
  • Jeremy Garchow
    November 30, 2017 at 1:03 pm
    No problem.
    Thanks for sending over all the materials. It helps to be able to see what is going wrong exactly.
Page 4 of 4
