Activity › Forums › Apple Final Cut Pro › issius with luts
Vegdo Rjabkov
November 27, 2017 at 8:17 pmNow i am speachless….
I i used the lut that was created with my Lightroom 6 (used on Mac)
and i used the lut that was created with Lightroom CC 2017 from the Windows PC of my brotherboth luts extraced with john r. ellis lut loader.
now when i am using both of them i get the same result as in Lightroom……..
here the image to compare exported out of my lightroom 6
Jeremy Garchow
November 28, 2017 at 3:02 amSo the Lightroom 6 LUTs do not work, but Lightroom CC LUTs work?
Vegdo Rjabkov
November 28, 2017 at 5:29 amNO, the CC lut looks diffrent to the Lightroom 6 lut. but wehen i use them together i get the same reslut.
now i installed lighroom cc 2017 also on my mac and all 3 luts looks diffrent …
Jeremy Garchow
November 28, 2017 at 4:44 pm[Vegdo Rjabkov] “now i installed lighroom cc 2017 also on my mac and all 3 luts looks diffrent …
“It is hard to diagnose the problem as it seems that at some point, you have two LUTs on, and others, you have settings enabled in the LUT filter that will alter the look of the LUT (“Intensity” etc).
Is it possible to upload the original TIFF and LUT so I can see what it looks like here?
Vegdo Rjabkov
November 28, 2017 at 8:53 pmi cant upload the .tiff it is bigger than 50mb
here is the lut that i generated in lightroom, how i want the video to look like:
11912_lutforcreativcow.cube.zip -
Vegdo Rjabkov
November 28, 2017 at 8:58 pmhere you can download via rapidshare:
https://www.rapidshare.com.cn/WC2EVP5and here is the picture how it should look like:
Jeremy Garchow
November 28, 2017 at 11:20 pmSorry, can you also export your LR settings as a preset?
Jeremy Garchow
November 29, 2017 at 4:43 pmThanks so much this helps.
When I go to export a LUT, it says that there are certain settings that won’t be transferred to the LUT, which is why you aren’t getting the expected result in FCPX.
See here:
If you turn those two parameters off, and use the Tone Curve to get a similar look, you will get a direct LUT transfer from Lightroom.
