Activity › Forums › Storage & Archiving › ISO:SAN over Gigbit Ethernet using DVCPRO-50 codec?
  • ISO:SAN over Gigbit Ethernet using DVCPRO-50 codec?
    Posted by Ben Howard on October 17, 2006 at 8:37 pm
    I know very little about the wonderful world of SAN. I have managed a Unity system and helped install a XSAN – but I didn’t have the chance to get under the hood and really learn how these types of systems work. When my budget allows, XSAN will likely be the direction I will head, but in the interim I wonder if I can pull off a poor man’s version of XSAN by living with a few limitations. Can anyone give me an idea if I’d be able to really work in the following environment:
    I’ve got 9 FCP systems, not all *need* to be on a SAN right now. 2 systems are dedicated to offline editing a series. Another 2 are dedicated to offlining another series. 1 system is a dedicated on line suite. What would be cool is if I could get the 2 of the offline suites (or even all 4) connected on a SAN. Ultimately, if the online suite could be on the same SAN and just mount the appropriate volume as needed, that’d be cool.
    I have copper fibre channel cards in 3 of the rooms. Those systems are connected to Medea RTRX 2TB arrays. It’d be really cool if I could locate all the arrays in one room and then share them between edit suites. As I said before XSAN *is* the way I’d like to do this, but I can’t afford it. So is it possible to do it on the cheap?
    One other thing that might be going in my favor: Due to some earlier decisions we are working at DVCPRO-50 codec. So we don’t have the overhead of full uncompressed. I was thinking that that might work in my favor to allow it all to work over Gigabit ethernet. Right now we capture everything at DVCPRO-50 rez and work thru the offline and then pass on the media and project to the online, via FW800 GRAID’s.
    Obviously a volume-locking san may be my best bet, but I just wondered if there was any way to make it all work without getting too crazy with buying new gear.
    Not sure if I’ve given enough info here…I’ll add to the info above if you needed to know more. Thanks.
    Ben Howard
    Howard Media Works, Inc.
    Ben Howard replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
