Activity Forums Adobe After Effects Isometric tire rotation
  • Isometric tire rotation
    Posted by Fabian Brugger on July 7, 2023 at 10:11 am
    So i have this isometric style project and its pretty low budget. Is there any simple/quick way to make the tires rotate? Of course rotation won’t work as its a isometric drawing and making it in 3d is too much work for this projekt. Is there anything that i could do to move the texture of the tire to make it seem like its rotating?
    Graham Quince replied 3 years, 2 months ago 2 Members · 2 Replies
  • Fabian Brugger
    July 7, 2023 at 10:29 am
    And yes i know the tire profile is in the wrong direction 🙂
    I thought maybe a stop motion kind of animation would work. Illustrating 4 parts of the rotation and just making it a stop motion rotation…
  • Graham Quince
    July 9, 2023 at 9:34 am
    Can you try a displacement map effect, which will use another layer as the displacement. You could then limit the movement to just the tires, probably by using the offset effect and you should get a hazy displacement that looks a little like rotation.
    Failing that, the liquify effect might also work.
