Activity › Forums › Adobe Premiere Pro › Isolating a color like FCP 3 way color correct does
  • Isolating a color like FCP 3 way color correct does
    Posted by Kevin Gonzales on February 28, 2013 at 6:11 pm
    Hi Guys:
    I am switching over to PP from FCP and was wondering if PP has a color correction feature like FCP’s 3 Way Color Corrector has, where you can isolate one color/highlight/background and manipulate as seen in the attached photos?
    Making the switch little by little.
    Thanks;
    Kevin Gonzales
    http://www.12point.net
    Kevin Gonzales replied 13 years, 7 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    February 28, 2013 at 6:32 pm
    You can do pretty much everything with the Premiere 3-way color corrector that you can do in FCP.
  • Kevin Gonzales
    February 28, 2013 at 7:02 pm
    OK, But how do I isolate, for instance the white background in this clip, and only manipulate that white and not the subject, in PrePro?
    In FCP, I can select that background and then use the luma and saturation in the 3 Way Color Corrector to blow the background out without blowing the subject out.
    Ideas?
    Thanks;
    Kevin Gonzales
  • Justin Parker
    February 28, 2013 at 7:21 pm
    in the 3-way color corrector, just scroll down to the “Secondary Color Correction” and it has a color picker, mask option and all those isolation tools.
  • Kevin Gonzales
    February 28, 2013 at 8:48 pm
    THANKS!
    Kevin Gonzales
