Activity Forums VEGAS Pro is windows indexing OK?
  • is windows indexing OK?
    Posted by Gilles Gagnon on August 20, 2013 at 7:04 pm
    A while back I read that Windows file indexing would cause issues with Vegas. I’ve turned it off but if it’s not true, I’ll turn it back on.
    ON or OFF?
    Gilles
    Gilles Gagnon replied 13 years ago 3 Members · 6 Replies
  • John Rofrano
    August 20, 2013 at 10:53 pm
    [Gilles Gagnon] “A while back I read that Windows file indexing would cause issues with Vegas. I’ve turned it off but if it’s not true, I’ll turn it back on.”
    Windows indexing itself doesn’t cause issues. What may cause an issue is that Windows may decide to start indexing when you need to perform some critical operating and cause hard drive contention. There is no reason to allow Windows to waste time indexing files. It doesn’t really benefit you unless you are constantly using the Windows search box to look for files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Gilles Gagnon
    August 20, 2013 at 11:00 pm
    Makes a lot of sense.
    Thanks JR.
    I’ll keep it turned off. The idea arose as I’ve been doing searches in the last couple of days. But the sleuthing is over… so I’ll keep indexing off.
    Cheers,
    Gilles
  • John Rofrano
    August 20, 2013 at 11:29 pm
    If you’re doing a lot of searches you might want to turn it on, let it index and when you’re done searching turn it off again. It use to be more of a problem when you were performing “real-time” processing like capturing a DV/HDV tape, but with tapeless workflows no one does that much any more.
    ~jr
  • Gilles Gagnon
    August 20, 2013 at 11:32 pm
    thanks
    Gilles
  • Nigel O’neill
    August 21, 2013 at 11:05 am
    Indexing serves no purpose other than searching on a Windows PC. Besides disabling indexing, I set my visual performance options to adjust for best performance, which disables a lot of Windows ‘eye candy’ such as shadows under menus, fade animations i.e. anything that can steal CPU cycles away from editing. I also set my swap file size manually to minimize page file fragmentation, disable my screen saver and use RAID to improve read/write performance. If your machine is not going to be continuously connected to the Internet, then disabling antivirus software will boost performance during edits and renders, but you have to be very careful that you don’t infect your computer when downloading Windows updates after forgetting to reenable the AV software.
  • Gilles Gagnon
    August 21, 2013 at 6:32 pm
    Very good points Nigel.
    I do question the anti-virus though. Unless you’re accessing files to be scanned by the AV or the AV is scheduled to do a scan or update, I’m not sure how it will get in the way.
    Gilles
