Activity › Forums › Apple Final Cut Pro Legacy › Is Uncompressed Video Format Compressed?
  • Is Uncompressed Video Format Compressed?
    Posted by Russell Lasson on April 10, 2007 at 11:52 pm
    Shane and I were discussing how the uncompressed format in Final Cut Pro uses compression. Here is what I’ve come away with. Please feel free to add to the discussion.
    The uncompressed format in FCP has a 4:2:2 color space. This is one metheod of compression according to the FCP manual.
    Quote-
    Some simple methods of data compression are:
    Throw away pixels at regular intervals: This essentially scales the image, or makes it
    more blocky.
    Average several pixel values together: This involves taking several adjacent pixel values
    and averaging them together, resulting in a single rectangular pixel that
    approximates the value of several. For more information, see
    Russell Lasson replied 19 years, 5 months ago 7 Members · 13 Replies
  • 13 Replies
  • Alec Gitelman
    April 11, 2007 at 12:26 am
    so how does “uncompressed” format compare to “none”? is “none” a 4:4:4 YUV format or RGB?
    also, my observation, “uncompressed” limits you to a 720×486 frame. if you’re exporting 720×480 dvcpro footage the extra 6 lines may cause a number of issues for you, especially when doing compositing and graphics.
  • Russell Lasson
    April 11, 2007 at 12:36 am
    Yes, what is that “none” thing about?
    The default size for uncompressed is 720×486, but you can change that to 720×480 by selecting custom on an export or just changing your sequence compressor.
    -Russ
  • Graeme Nattress
    April 11, 2007 at 3:38 am
    Yes, “uncompressed” is compressed in the sense that it only records 2 out of every 4 chroma samples, but it’s uncompressed in the sense that it does not throw away any of the data it records.
    No point going 4:4:4 with DVCproHD or HDCAM though – no benefit at all, really. I don’t think any of those decks will do 4:4:4 anyway – you’d have to go to D5 or HDCAM SR for that.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Rafael Amador
    April 11, 2007 at 5:59 am
    [Graeme Nattress] “Yes, “uncompressed” is compressed in the sense that it only records 2 out of every 4 chroma samples, but it’s uncompressed in the sense that it does not throw away any of the data it records”
    That the point. What is the difference in between 8b Unc and DVCPro50? The two of them are 8b, 422. The two of them record the half of the chroma information, but DVCPro50 apply some other kind of compression (DFT or DCT or so, I’m not sure about now) to get smaller files. 8b Unc it writes all this information as it is without applying any other form of compression.
    Cheers,
    rafael
  • Martin Baker
    April 11, 2007 at 7:45 am
    QuickTime None codec is 8 bit 4:4:4
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! Final Print for FCP
    Hot Tips video podcast
  • Petteri Evilampi
    April 11, 2007 at 9:23 am
    We all know that dv, dvcam and dvcpro are highly compressed, 4:2:0, 4:1:1.
    Doesn
  • Graeme Nattress
    April 11, 2007 at 1:11 pm
    Yes, the 4 implies a full resolution luma, or Y. I’ve found that old film on DV PAL looks very nice indeed, but it all depends what format you got it telecined to.
    Graeme
  • Peter Dewit
    April 11, 2007 at 2:18 pm
    Compression isn’t jsut the chroma subsampling. Uncompressed footage will also give you a higher datarate and thus better quality. That being said capturing uncompressed isn’t going to eliminate any compression that was there to start with. DV footage, for example, is already highly compressed on the tape itself. The DV codec in FCP is designed to match that compression method thus really nothing is lost loading DV footage in as DV. Likewise you really aren’t going to gain anything loading DV in uncompressed since there isn’t enough information on the original tape to provide that quality anyway. There may be other reasons to bring it in using the Uncompressed codec like mixing DV with other tape formats and titling. I’m not sure but I think effects might look a bit better on an uncompressed timeline too.
    For your film project it really depends on the format you are getting telecined too. If you go to a higher quality format like Digibeta loading in uncompressed might be worthwhile.
  • Russell Lasson
    April 11, 2007 at 3:44 pm
    [Russell Lasson] “So, is there a loss when you go from a 4:1:1 or 4:2:2 compressed format to 4:2:2 uncompressed? Will uncompressed 4:2:2 through away half of the color information or will the program doing the converting figure that it doesn’t need to because the color space is less than or equal to the uncompressed format and just translate (not compress) the current values into the uncompressed format, thus not losing anything?”
    -Russ
  • Rafael Amador
    April 11, 2007 at 5:40 pm
    Yes but the quetion of Russ haven’t been answer. Supose that we had telecined a B&W film. We record it in 8b Unc. Then we make a copy in DV. Would be any difference in between the two movies?
    In theory, I think, it shouldn’t be any difference. If so, as Russ says, working in DV would save a lot of space in his HDs and the quality of the final movie would be exactly the same.
    Russ, probably the best is if you make some tests. I would suggest you to apply a CC filter and put the saturation all the way down. just to make sure that there is not any remaining Chroma. This i would do it just because I’ve got no idea about telecining:-)
    Cheers,
    rafael
